Been using lorex nvrs for a few years, tired of the software they use.
Here's my layout....
Home network, 40+ clients wired and wireless. Asus GT11000 router, 2 other asus routers in AImesh mode. All networking works fine atm.
Lorex NVR is cabled to local network as well. I can view on PC, or switch source on samsung tv to hdmi for nvr viewing.
9 cameras, 4k, setting future expansion number to 16 possible total, for now. All are ONVIF. 1 of the 9 is a ptz, should be no problem in BI.
I will be fixing up an older pc by adding drives, ssd for boot and wd purple for cameras. This older pc will only be used for blue iris, -maybe- in the future running homeassistant in docker, that (HA) currently is on a Odroid nuc.
Older PC, i7-9700K, 16gig, z370 MB. No graphics card currently. That, and all drives were swapped to new build.
I'm going to record 24/7, and plan on using the deepstack ai, i've seen how to set it up on the hookup (youtube)
I see the WD purple 10-tb on sale for 318, I was thinking that's a good amount of storage. Or, might use the 6tb purple currently in the lorex nvr.
So, here's a few questions that I've learned I need to ask, so far.
Is it recommended to get an add on NIC card to keep the cameras on their own network, although I want to be able to access BI remotely and locally (tv and PC) for viewing?
Can I use both the 6tb purple and a second wd purple for camera storage through BI ?
is 9+ cameras going to bog down my current router? I do have an extra newer router (asus RX-55) if that's needed somewhere in this setup.
POE switch, I know is needed. I think I see where you just plug all 9+ cameras into the POE switch, then plug poe switch into a/the router (right?) or, using a second nic, should I possibly plug poe straight to PC second NIC, then use primary nic for current home network for access?
I need recommendations on POE switch boxes to use with this setup.. I saw a 16 port unmanaged switch on amazon for around 159.00. ?? Amazon.com: MokerLink 16 Port Gigabit PoE Switch, 2 Gigabit Uplink, 250W IEEE802.3af/at, Rackmount Unmanaged Plug and Play Ethernet Switch : Electronics
Will I gain anything by using a cheaper graphics card, versus the CPU integrated ? I do want higher quality video where possible.
Using what I have now, getting purple drive for data and ssd for booting the older pc, which poe switch to buy, anything else I'm missing? And if I need to add/clarify anything, please let me know.
Thanks in advance!
Thanks in advance!
