Just picked one of these up myself, seems pretty nice for $40. I’ve had to play for a few days to figure it out though, I’ve zero experience with these. This may be helpful.
https://gzhls.at/blob/ldb/c/a/7/e/12197c16d394315157120a093f2cb5a0b6a1.pdf#page59
You should get the cable to at least set the password to it. You can pick up an HP one for a few dollars. If you have problems later with the password you can wipe it by holding the clear button for 1 second.
There is definitely a learning curve with this thing!!
I was able to get DHCP to work after doing a factory reset as that is the default setting. From there I was able to access the web pages for configuring.
