Hi all,
Just a little question.
Previously i was able to connect to my Dahua NVR, using computer browser (edge/chrome) by using fix IP that was defined in to the NVR.
Now since a few day, unable to access the NVR over the network... When i go in my basement, I can still access the device, IP/DNS etc has been set correct... but when i want to use the testbutton for network, failed!
DNS is classic google ones 8.8.8.8 & 8.8.4.4. Ping does not return either... i see on the same network as the NVR.
I love this feature, because i don't need to travel each time to basement
I have seen that you can export the CA certificate and import it to my computer, but don't know if it will fix my issue here...
kr
David
kr
David
