I want to build birdwatching camera. I have zoom lens from old video camera with focal length 10 to 120mm. My idea is to use cheap Chinese WiFi camera module and lithium battery pack. Is it possible to connect those module to Android directly, without router. Camera as AP or WiFi direct? AP will be best, especially if more than one user can connect simultaneously.
Which module type (Hisilicon family CPU or something else) to chose?
My lens was originally made for true 1/2" sensor, so big sensor will be the best, but I found only expensive IMX185 without WiFi.
Lens
is from Blaupunkt SVC100 camera. Holes on mount ring are exactly right for 38 x 38 module. When another 2 spacer will came from China, I will post some pictures, those I get with only 2 spacer is great, sharpnes and low light capability with 1/3" IMX225 board is exelent.
2 maybe suitable 1/3" modules
Cost Promotions High 960P CCTV Network WiFi IP CAMERA Module Hi3518E+SC1135 HD 130MegaPixel With WiFi Module For Network Camera-in CCTV Accessories from Security & Protection on Aliexpress.com | Alibaba Group
960P HD 1.3MP Ar0130 Low Illumination wifi wireless Wi Fi CCTV Network IP Camera Board Module with Audio interface, Onvif-in Surveillance Cameras from Security & Protection on Aliexpress.com | Alibaba Group
Lens
