It seems like people are doing this effortlessly. I have an ipc-hfw2200s.
I installed ConfigTool and it will recognize my NVR when the NVR is connected to my router on my home network. But ConfigTool will not recognize my cameras no matter how they are plugged in. I tried through the NVR with the NVR connected to the router, then directly to the router with a PoE adapter to power them, then directly to the computer ethernet port with the same power adapter. Nothing pops up when I hit refresh in the ConfigTool.
The NVR assigns some sort of IP address like 10.1.1.XX when viewed from within the NVR.
I hit the "log in" button at the bottom of the config tool (with an empty list) and it reveals 192.168.1.108 and all the password/login fields are filled in. I even retype them but nothing happens, except the message "login failed".
I really thought it would be much more plug and play than this. The cameras work fine with the NVR, on a closed system. I just want network functionality.
What's the secret?
My network is practically untouched. I think its on OpenDNS, but that's the only alteration. Basic gateway: 192.168.1.1
What's the secret?
