I am looking for advice on a unique application. I have a Reolink NVR on my boat and would like to use some sort of Ethernet switch to connect an existing ray marine ip camera to the NVR so I could remote monitor using the Reolink app. The rub is I also need to leave the camera accessible to my ray marine axiom display on board the boat. This is why I think I need some sort of Ethernet switch. That will provide power to the camera for use on either the Reolink or the axiom.
The camera is a ray marine cam220 an
the NVR is a Reolink RLK8-810B4-A 8mp 8 channel NVR. Any help in trying to figure out how to make this work would be appreciated.
The specs for the camera are:
Specifications:
Specifications:
- CPU: 32-bit ARM9 RISC CPU up to 432MHz
- Flash / SDRAM: 128MB / 128MB
- Image Sensor: 2.0 Megapixel 1/2.8" SONY progressive scan CMOS(Exmor)
- Total Pixels: 1952(H) x 1116(V) 2.18 Megapixel
- Effective Pixels: 1944(H) x 1104(V) 2.15 Megapixel
- S/N Ratio: More than 50dB
- Minimum Illumination: 0Lux (IR On)
- IR Distance: 20M (4 Built-in High Power LED's)
- Day & Night: ICR
- Lens: 3.6mm Wide angle Megapixel Board Lens
- Field of View:
Horizontal = 51.0° +/- 3°
Vertical = 93.0° +/- 3° - Video Compression: H.264 High [email protected], MJPEG Image quality: 3 Steps
- Resolution: Up to 1920 x 1080 (Full HD)
- Frame Rate: H.264 Up to 30fps with 1920x1080 | MJPEG Up to 30fps with VGA resolution
- Video Streaming: Support multi stream with H.264, MJPEG Adjustable frame rate CVBR/CBR in H.264
- Pan / Tilt / Zoom: Digital Pan, Tilt and Zoom
- Image Setting:
Day & Night
Auto White Balance
Shutter Speed (1/41/2,000)
DSS
BLC
Brightness, Contrast, Sharpness, Mirror - Security: Password protection, User access log, HTTPS encryption
- Supported Protocol: HTTP, HTTPS, FTP, SMTP, UPnP, DNS, DDNS, NTP, RTSP, RTP, TCP, UDP, ICMP, DHCP
- Intelligent Video: Motion detection up to 1920x1080 with 12x12 blocks
- Power Source: DC12V/1.5A, PoE(Power over Ethernet): 802.3af
- Power Consumption: Max. 5.4W, with IR
- Net Weight: 230g(Camera Only)
- LED's: Power, Network Connection
- Dimensions: 178mm(D) x 66 Diameter
- General Operation Temperature: -10°50° Celsius(14F122F)
- Storage Temperature: -20°60° Celsius(4F140F)
