I'm using BI pretty minimally right now... .just 5 cameras with recording turned on for only one.
I'm using it in combination with a home automation setup (Vera) and setup geofencing to turn switch profiles through a vera scene when i come and go. I have no schedules setup, and the 'enable' box on the schedule tab is NOT checked.
Here's where i'm confused.
Often, when i leave, i can check my phone and see that the profile correctly set to 'away'. However, if i check again several hours later, there is no longer any profile selected. It's as if it resets at some point.
On the BI console, i'm a bit confused by the UI as well. There is a button for 'temp/hold/run' profile that will change colors, in addition to the 7 profile choices. I assume i want this to remain at 'hold' for whatever profile i select.
Any thoughts greatly appreciated.
