Not sure what happened, but all of my alerts disappeared. I don't recall making any changes. Even for current alerts, I get the notifications via text and BI app, but when I try to access the clip, it's not there.
As I trigger the motion alert, I see the image of the alert pop up in the alert list, but it just disappears. I have my database and alerts folder stored on the Operating System SSD and the recordings stored on a 3TB HDD. The SSD has over 80GB spare and the HDD has over 1TB to spare.
For the Alert folder setting,I had "Limit clip age" set to 7 days and delete was selected. I assumed this would only delete clips older than 7 days. Is this not true?
On the bottom bar where it says "Blue Iris options, configuration, user preferences," it says this: "Clips 3083 files, 1.01T /0.99T.
I just noticed I had my "New" folder set to 1000 GB limit. Would this affect the Alerts folder? I just increased this folder to 2000 GB. Will let it run for a bit and check back later. May have fixed the issue, but still don't understand why the historical alert clips disappeared.
Sorry for the rant. Kinda working through this issue as I type. Thanks.
