Zxel
Sorry, but there is no way an a 920 overclocked to 3ghz will outperform a stock 4790...not possible..something else is wrong. I would not recommend overclocking a NVR pc...its will destroy the power consumption...
It does seem like quite a stretch, it could be he has a setting in the BIOS wrong making it worse, however, speeding up the memory bus has a way bigger impact than you think, and of course there is always the energy saving functions for the 4790 (including underclocking and overclocking itself automatically). I do agree somewhat with the power consumption thing, however, if his computer is pushing over 70% ALL the time as a NVR the power saving features of the CPU wont have as big an impact. If it was me I would overclock the RAM (lower the timings specifically - don't care so much for a speed increase), and monitor the power consumption as I was overclocking. I bet he can OC it without dramatically affecting the power consumption that much.
I remember OC'ing an AMD 386 in a computer I had that beat everyones fancy new intel 486 (which was a fortune at the time - pissed off alot of my friends that just paid over $1,000 for there fancy i486) - hehe (showing my age here). I can speed a computer up significantly without affecting the power curve of it, I know because I'm doing it on this computer - it uses exactly 3 watts more than when not OC'd (and I didn't OC the CPU at all - just memory, video, and bus timings). Never underestimate a well balanced system.
Just going thru the OC'ing process might help discover a MB setting that is set wrong - I'd just keep an eye on the power usage (as you suggest).
