Two IP cameras can suffer configuration settings loss when power is disconnected or at auto-reboot. It's happened about 4- 5 times since May. Auto-reboot is Tuesday 3:00am. NVR reboots at 1:00 same day. Behaviour isn't always identical. Sometimes IP address is changed, sometimes not.
I've done a good amount of reading on the subject. There are numerous reports of similar behaviour from a variety of brands. Various remedies were proposed...
Setting firmware auto-upgrade to off.
Requesting firmware update
Deactivating auto-reboot.
Reformat HDD
Reserving IP addresses in router.
A question arose about the saving of the settings. Perhaps we aren't doing all the steps correctly. Is there need for immediate reboot to properly save ??
Most recently I saved the cameras config file so was able to quickly get back to normal. Clearly I'd prefer a solution so we can leave the system to do its' work. Is there a way of making the correct setting, the default?
Any thoughts, ideas, tips appreciated.
Thanks.
Ip cameras: Besder
NVR: Besder POE 8ch
IpCam
NVR
Reformat HDD
Thanks.
Ip cameras: Besder
NVR: Besder POE 8ch
IpCam
NVR
