Configuration Comparison
Dorsey Pender
Sep 7, 2019
209
29
San Francisco
Is there a way to take a known good camera configuration and compare it to the others? I am using DeepStack and one camera's settings are working very well and I would like to clone them to the other cameras, however they are not all the same make and model. Any way to do this easily?
Not that I am aware of. Occasionally even copying the same camera over to a new camera of the same model has issues, something in the configuration gets sideways.
You can create a new camera and select "Copy from Another Camera", then do a find/inspect which should get all the settings over. But, if the cameras have different resolution, motion detection and zones and hot spots will likely be off.
If you are looking to clone a camera's GUI settings like brightness, gamma, etc., the best way is going to be to take a picture or screenshot of the settings and use that as a guide.
I've found that even the same model camera in a different location needs different settings to perform at its' best. Copying, other than a clone and then setting different zones, DS and so on, is as close as you can get.
