What should I be using to connect the conduit to where the ethernet exits the house? The previous owner had some conduit exiting the garage for a security light and it looks like they just jammed a inside corner pull elbow into the opening but I'm not sure if that is right
Do I need to put a piece of the conduit through the hole (gonna need a much bigger hole then) and then attach the elbow to that?
