This is not about my BI machine, this is my everyday machine.
Windows 7 Pro.
When powering up, I get the Windows failed to start screen, and the open to Start Normally or Startup Repair.
If I choose startup repair I end up back at the same screen. If I choose start as normal, after a long wait, computer starts, windows colored window cube appears above starting windows. Then at the point you believe windows is starting, screen goes black, and then just sets there.
I have tried using the Win7 repair cd I made, basically same results.
I have tried using the original Win 7 install disc. Choosing repair, I end up with just the background for repair options, but no options actually ever appear.
I have tried another known good video card, no go.
I have ran memtest, no errors.
HD is recognized in the BIOS, with proper model # displayed.
I have tried to find a bootable CD version of the WD testing program, my search fu must suck.
All fans are running and very little dirt anywhere.
I am assuming at this point that the HD has failed, although I'm hoping that the MBR is simply messed up.
I don't have another SATA drive to test with.
If it matters, this is a machine I built about 6-7 years ago, with an I-7 xxxx and gigabyte mb, gskill memory. Never gave me so much as a hiccup until yesterday when I tried to power on.
Any suggestions are welcomed and greatly appreciated.
Thanks.
Windows 7 Pro.
Thanks.
