Computer i7 2700 BI Question
botics
Getting comfortable
Feb 9, 2019
245
113
Coral Gables, Florida
I have a i7-2700K @ 3.5GHz with a 1TB SSD and 16gigs RAM 1333Mhz.
Anyone running a similar processor or has? Looking for info to see if it worth the time to setup BI on.
Thanks
It is okay for BI. I'm not sure it can do hardware acceleration for resolutions higher than 1920x1080. I wouldn't necessarily buy one today though unless it was a really great deal. Each newer generation beings a small performance and efficiency gain, and the second generation is about 7-8 years old now!
Reactions: TonyR
It would be fine for small to medium sized setup, i think. if it does the job, use it!
main difference is the cost in electricity to run that CPU compared to more modern ones...
we had Sir Tim Berners Lee in the office a while back. I can't remember what we were trying to show him on the big touch screen...Paul_and_TBL.JPG
Reactions: TonyR
Thanks for sharing.
Does this jog your memory?.....Lower right on screen, it says on first line "Showing cities with bits (or hits?)/sec of..." and below that "0 to 1,938,682"
heehee. hi rez, indeed. that's our global traffic map display. we overlay the data onto Google maps to impress visitors. hits/bits per second per pop, attack traffic, that sort of stuff... here's the current view of our 'spikey globey' thing showing real-time attack traffic on global scale. Oh how things have changed in 30 years... :-)47363223811_7558532192_k.jpg
Reactions: awsum140
