That processor certainly has some passmark horsepower...does it include Intel HD Graphics for BI graphics acceleration?
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]
[/TD]Use the 6700 with intel HD...the hardware acceleration is significant. That xeon is end of life.'
What is the resolution of those cameras? What frame rate will you be using?
Yes they are old I have a 2 cpu box here with no use thought I may try it. It does use a ton of electric, 600 watt PS with scsi drives and screaming fans
I have a mix of hiki @ dahua bullet cams and 2 ptz dahua. Would like to run them as close to full frame rate if possible 25 fps. All new cams that I am running at full resolution
Not sure if an i7 has enough. I have 6 cams on an i7 , 16gb mem desktop internally to watch my doggys and its pulling about 33% cpu
Still trying to sort the inner workings and optimization of BI. I'm very new to this
Any suggestions greatly appreciated
...I'm very new to this...Any suggestions greatly appreciated
Your running direct-to-disk option on, correct? Also, why the need for the high frame rate? Do you have a contractual obligation that mandates a high frame rate?
Direct to disk isn't just about CPU usage. It is higher quality since you don't have a twice-compressed video file.
