I'm after suggestions on what I could do to better protect my 50+ cat cables entering my server rack from a non-standard size hole cut in the plasterboard. At present, as a temporary measure, I've inserted thickish carboard under the cables so at least they shouldn't be nicked or damaged by the rough plasterboard edge. The cables as viewed in the photo, run horizontally to the left behind the plasterboard. The black cables are coax and the white cable is low power cable to the doorbell.
Steve.
Steve.
