Color4K-T180 and PFB203W distance from the wall?
Joepoe
Nov 11, 2021
15
11
There where Home is
I'm considering some Color4K T180 180 degree cam's, wall mounted. However, near the mounting points will be some downspouts/rain-pipes which stick about 6"/150mm from the wall. Will the T180 with wallmount stick out far enough to maintain the 180 degree visibility?
I've been looking at the size drawings but to me that's not conclusive. Anyone with a measurement?
I also notice the camera specs: Field of View H: 180°±10°V: 48°... Do they actually reach 180 degrees?
I have a T180 mounted on the back of my patio about dead center on a 16' wall using the PFB203W mount. I also have down spouts on the ends of each side of the wall corners and here is what I see. Please ignore the nasty backyard as we are preparing for some landscaping....
You can sort of see the downspout in the right more so than the left side but its a good or VERY close to 180 view.
Reactions: Joepoe
