- Dec 24, 2016
- 410
- 320
I'm using CodeProject LPR and I'm having some issues reliably capturing plates. The illustration below shows what I think is the problem.
Here's an analysis of one of the AI DAT files:
The car moves from right to left; as you can see, at T=0msec, the bumper of the car is just barely in frame.
If I click on any of the images BEFORE T=0, ie T-800msec, the same frame from t=0msec seems to be used and hence there is no valid detection of plates:
The same applies to post-trigger frames; they seem to be relatively static. In all cases when the image is repeated, the analysis bounding boxes are the same, so it does look like the AI got the same image.
I can scrub through the results in the trigger preview with AI analysis turned on and it seems to work.
Curious if anyone has run into this before?
