Codeproject - cant view installed modules
Jul 4, 2015
27
4
See attached screenshot. I updated my inlaws PC and now i cant view the modules to start/stop them or even install or uninstall them. I thought something went wrong with the program so i uninstalled it, deleted the folder in program files and reinstalled everything. I was able to see the modules for the first few times i was on the page then they went away. I tried in firefox, chrome and edge. Is there a way i can edit the files to start the Yolo11 module that i installed. (yes i was able to install the yolo11 module and now i cant even see the module installation page options)
Can you see them if you click on the "Install Modules" tab? You will not see them when viewing the :Status" tab if they are not installed and started!
I think i figured it out. For some reason i needed to reinstall .net 8.11 and it seems to have fixed the problem for now. Thank you!
