How are modules removed? From the dashboard, Status shows that I am using Object Detection(YOLO6.2), The InstallModules tab shows I have also got installed Object Detection(YOLOv5.Net) " best for those on Windows and Linux without CUDA enabled GPUs", this module it's not showing as being used in Status. I have a CUDA enabled GPU, so is it OK to remove Object Detection(YOLOv5.NET)? It so, how do I do this, remove this module?
What's with the Super Resolution module currently not installed? Increases the resolution of an image using AI apparently, sounds like it's something I should install, so install it then?
