Code Project constantly restarting when Blue Iris is set to Auto Start/Stop - Solved.
fenderman
Staff member
Mar 9, 2014
36,891
21,417
This was not an issue for me on 2.0.8 but on later versions 2.4.7 included CPAI goes into a start stop loop when the box in the blue iris AI tab is checked to auto start/stop cpai. It seems to only occur when choosing to use the gpu (intel in my case with yolo v5 .net), however I did not perform extensive testing. Simply uncheck the box and you are good to go. Dont worry, cpai will start up properly on its own when you reboot.
I believe is read this suggestion some time ago (maybe from @MikeLud1) somewhere deep in the CPAI 2.0 thread.
Reactions: Fhantazm
