Cloud Gateway Ultra question
bslow47
Jan 4, 2022
84
25
Texas
Good Morning All,
I had replaced an old router with the UniFi Cloud Gateway Ultra. As I was reconnecting the network back up I had temporarily connected two computers by ethernet to the gateway. I have since reconnected those computers to a switch that is connected to same gateway.
When I log into the gateway, via browser, and view the network, topology, ports etc. I will notice that the ports, on the gateway, where I had the two computers hooked up (and a beacon I had never hooked up) icons are still on the ports I had them on. They are grayed out though. The computers icons are correctly displayed on the switch (Unifi US8). So why will the icons still remain (grayed out) on the gateway? And why is there a Beacon icon grayed out that was never and can't connect to the Gateway because it is wireless and plugs in to a wall plug.
Thanks,
