- Jun 24, 2017
- 60
- 37
In a recent post here I mentioned I had ordered a new HD camera to replace an older model which was only SD, and the image needed to be sharper. The old camera is a 'Y-cam white' model, very flat and compact and fits in a concealed cavity I made specially for the purpose. Because of this, I ordered the 'Y-cam Homemonitor HD' camera because it has exactly the same outer case. It arrived today, and now I find that it's designed to be cloud-based and although I can view its image with ethernet cable I can't get into its settings or connect it to my Blue Iris system. Its eventual use would be with ethernet cable, not wifi, does anyone have a workaround to circumvent the cloud based lock-in?
