sneakynuts Getting the hang of it Feb 9, 2019 39 26 Sydney, Australia May 2, 2021 #1 I have my blue iris running in a VM with a purple drive passed though with full access Every so often i get this in my logs: I just cant seem to narrow down the cause. Any where i should start looking?? This is my storage tab, if its of any help
IAmATeaf Known around here Jan 13, 2019 3,420 3,394 United Kingdom May 2, 2021 #2 What are the log entries before the error occurs?
sneakynuts Getting the hang of it Feb 9, 2019 39 26 Sydney, Australia May 2, 2021 #3 Ive since cleared the entries, but next time it occurs, ill paste more of the log.
SouthernYankee IPCT Contributor Feb 15, 2018 5,182 5,355 Houston Tx May 2, 2021 #4 I get those errors on my network drive. I think my problem is a time out caused by overloading it with writes.
sneakynuts Getting the hang of it Feb 9, 2019 39 26 Sydney, Australia May 3, 2021 #5 Heres another screenshot of when the errors occur It seems i have a seperate issue of my cams randomly disconnecting then reconnecting. But it doesnt align with the clip write errors Also, how do i change the timezone of the App Sunset/sunrise - They are def. not correct for me!!
sneakynuts Getting the hang of it Feb 9, 2019 39 26 Sydney, Australia May 3, 2021 #6 SouthernYankee said: I get those errors on my network drive. I think my problem is a time out caused by overloading it with writes. Click to expand... Thanks - Glad i'm not alone - At least it keeps recording! Even if it is multiple smaller clips!
