- Oct 6, 2017
- 119
- 17
Hi folks,
I have one concern and one question.
The concern is that on the BI interface the little graphic that shows the chart on it above the clip previews is showing red, and when I click on it I get a clip storage overview that looks like attached. As you can see Drive E: does not look right. (All storage drives are identical). To try to remedy this I tried rebuilding the database and running CHKDSK /f /r on all drives and it did find some things wrong with a couple of the drives but did not change attached.. Any idea what might be causing this for things to try?
My setup is I have 14 cameras total about half of them 4 megapixel and the other half 8 megapixel evenly distributed pointing to these three drives.
The thing that brought my attention to this was that BI was creating a new clip every 10 seconds (on drive F
and that clip would only be zero or one seconds long, (BI did not create a file for these ultrashort clips) CHKDSK seemed to fix this problem.
And my question is what should be my maximum file size? Currently I have it set for 2 GB and this gives me about 30 minutes or one hour depending on camera resolution for each file. I would like to increase that to get fewer files if possible..
Thanks in advance, James.
