Something isn't making sense here.
You cannot use the move function from within BI to pick and chose and "move two files from a cluster**** of clips to a location" - it does the command for EVERY file that meets that criteria - you cannot simply select two files.
Clearly you manually moved two files outside of BI....
Here is what it shows - you either can select Delete, Recycle, or Move to folder.... You could not move and have Delete radio button on at the same time.
You can either:
You can either:
- Delete it based on a size or age limit
- Recycle it (but why)
- Move it to another folder, at which point it deletes where it is currently, and then you must have moved it to a folder set to delete without a size limit or age limit...
