Clearing Blue Iris Status Connections Log
pepperfr
Feb 8, 2015
136
52
Ohio
I have been curious for some time now about the Connections tab on the Blue Iris Stats window (you get to it by pressing the Graph toolbar icon). This view has a "Clear" button, but it only seems to clear connections with no Object. The connections that have an Object of "login" do not get cleared from this view. Apparently these are active connections since they are not greyed out. Is there some reason that the Clear button doesn't clear all of the connections in this view? My system seems to accumulate connections with the "login" Object. Is there some reason these connections remain active and accumulate?
Same question here. Almost looks like something remote, judging by ip, (not me) is trying to login
