While reviewing recorded footage, I noticed that random chunks of footage are missing like they have been cut out. Sometimes it's just a few seconds and sometimes it's several minutes. I am really puzzled buy this. The following is my system setup:
Blue Iris 3.66, on a Win 7 Pro 64, i5 650 cpu @3.2 Ghz (1st gen), 4GB ram, 2 hard drives (small with the OS on it and big 4TB WD purple for BI recordings) This is a dedicated computer for BI - no other software running
5 Hikvision 3MP cameras recording at 2-4 FPS each, in full resolution, motion detection is run through BI
Entire system is wired via Cat 5, POE
RT-N66U gigabit router, Zyxel GS1900-8HP POE switch
CPU usage normally hovers 30-40%
Is BI dropping chunks because CPU is old? Is it motion detection that's messing with the recording? How would I go about troubleshooting this?
Btw. the chunks that are missing have motion in them.
Thanks,
J
Thanks,
J
