Chrome App for Dahuas
nayr
9,229
5,330
Denver, CO
For Dahua IP cameras and video recorders; Not the greatest solution really, but it works after the death of the GSSAPI plugins.. on Windows/Mac/Linux
Install: NACL Web Plug-in
Note this is a Chrome App, you have to launch the app and it will open a new browser window will open.. Regular chrome still wont play back video.
It seems this only works with recent Dahua firmware. Unless I'm missing something?
Tried it with chrome.using windows 7.tried to login into dahua nvr.clicked on login button and nothing happens.
Worked for me running chrome on a macbook :)
Go to "more tools" then extensions, then select the NACL Web plug in
Click the green launch app button
You should see a new "web service" window pop up.
In the URL box, type in the IP address of your camera.
It should let you log into the camera, and then the live window should show video, at least that's how it worked for me.
Took me a little bit to figure this out.
It worked for me for a while on Windows 7 then stopped working a few days ago for some reason. I launch the app then it kills the tab without launching a thing. Haven't spent the time to figure out why yet.
It did not work for me on Chrome in windows 10, but IE tab is working on Chrome.
This isn't working for me either. Using Linux with the Chromium app. I get to the login page and if I put the incorrect pw it immediately tells me. If I put the correct pw, it doesn't do anything. Nothing. Just sits there like I didn't hit "ok"
Reactions: cor35vet
What camera? seems to only work with newer firmware
One of the 5231 starlights I got yesterday. I'm running Linux Mint and am having a difficult time setting this camera up. Can't download the plugin for firefox in linux so that's how I found this thread. What is the best way you'd suggest accessing this camera's settings? I can manipulate the settings in firefox but just can't see the video feed.
open video feed in VLC
rtsp://<IP Address>:554/cam/realmonitor?channel=1&subtype=0
Yesss thank you. Have been looking for that because I know I remember you posting that, probably in the other thread. Could have sworn I screen shotted that on my phone but it wasn't there. Got it working now in VLC thanks!
nope, set your self up a windows VM
Reactions: DavidDavid
How do you launch the plug in app first?
Also, any idea if this will work at all on Android devices?
new tab, apps in upper left corner, nacl web plugin..
if linux users cant get it working I doubt it'll work in Android
So IE tab won't get live feeds going? I can hit my web service and log in with chrome, but no live feeds. NACL plugin the only way now?
i know this is a thread about chrome but i found this works for firefox since version 52 and higher killed the plugin. Worked for my hikvision and dahua plugins to work on firefox52 and later.
OP
Hikvision plugin doesn't work in Firefox
As of Mozilla Firefox v52.0 released on March 7th, NPAPI plugins are no longer supported. This means that, much like Google Chrome, Hikvision users will no longer be able to successfully install the web browser plugin required to view their cameras in Firefox.
This was announced in the Mozilla Future Releases blog post from October 8th 2015 and has now finally come into effect. Chrome discontinued support back in September 2015, and you can see the impact this had in our thread on the topic.
Fortunately, there is a workaround:
- Type about:config in the Firefox address bar – ignore the “are you sure you want to proceed?” page
- Right click anywhere. A context window should pop-up
- Select New >> Boolean
- Enter exactly plugin.load_flash_only
- Set the Boolean value to False
- Restart Firefox
For now, this should work as a temporary workaround to restore full functionality to your Hikvision system.
NB:
I have been unable to get this feature to work on the Firefox version of Mac OS X
This only works when using TCP transmission protocol - NOT UDP.
However, a similar fix was present in the first version of Google Chrome that removed NPAPI plugins, and this was subsequently patched out. I wouldn't expect this Firefox workaround to last forever unfortunately.
