fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,409
@mcx - was that video in WMP downloaded to the machine before being played? I assume so since I don't know of a way to stream to WMP. If it was in fact downloaded prior to being played that may be why it is smooth. No buffering.
What about the other two, are they both being played from a stream? Sounds like you are playing the file from a remote BI server?
Any anti-virus on the test machine? I ask because my remote test machine doesn't have any installed, but the local machine does.
To clarify, I viewed his server remotely and see the jitter...he did not view mine.Wait, so you view Fendermans server that everyone knows is fine and you still had a problem? Its not your networks... sigh. you came to the exact opposite conclusion you should have.
Its your computer.. not the server nor the network
