System
Bare metal install, Xeon E3-1275v5, 32gb ram, deadhead Quadro P1000 (CodeProject), 4TB WD Purple -Storage, 250gb NVME db/new/alerts, WinServer 2022 on SSD, dedicated dualport Intel nic bridged to 20 port BVE POE switch, 2 cams 4k 30fps, 2 cams 4k 15fps, H.264H, VBR for both main/sub stream, anamorphic, I-frame matches framerate and framerate in BI matches cameras, main/sub streams stats all look correct, continuous main stream record to disk/intel+vpp/gpu:any/also BVR. Stats show 4,850 kB/s 25 MP/s, CPU 19-25% GPU 19% RAM 3.29. Didn't realize updates expired in Dec so paid/updated and now I'm having issues it seems.
Live playback in console is fine (even with live preview rate @ 30fps/full screen), clip playback is jerky at 1x but is smooth at 1/2 and 2x+. Even with cameras disabled, hardware decode enabled/disabled, does not matter if clip is stored on NVME or WDPurple. CPU only goes to 30-50% on playback with live view enabled, with all cams disabled CPU 12%, GPU 20%. Clips play perfectly in VLC when exported H.264 w/without re-encoding overlays. What am I missing?
