nymphaeles
- Nov 28, 2017
- 92
- 59
I use a Fractal Design Define R5 case that can house 8x 3.5 HDDs, & 2 bays for DVD-ROM, plus some two SSD. I like these Fractal Design Define PC cases as they are built like a tank and provide excellent noise reduction. Don't forget that the number of HDDs you can put into a PC case not only depends on how much SATA ports available on your motherboard, but also the capacity of your PSU. I'd rather go with larger capacity dirves than go with more drives. I used to used 4x 4TB drives, but I recently upgrade them to 4x 8TB drives and double capacity of the system. Recently, there are 10TB and 12TB drives available on the market and that provides excellent choices for large capacity systems.Wanted to get general opinion here we are in 2020. What pre build if any would you guys pick say for blueiris PC in case prespective for say a i9 9900k ? Specially when you know you are gonna say put 5-10 Hard drives 3.5 inch. If there is no pre build what cases would you recommend ? Thank you !
Cheers.
