Checking In and pfa130e junction or pfa137/139?
trucams
Nov 6, 2017
96
79
Greetings, just checking in as a new user. Thanks to all for the wealth of information and Resource Guide and VPN For Noobs stickies.
Plan on a couple Dahua wedges near some well covered doors (outside covered porch and inside garage). It looks like the pfa139 junction box has a smaller profile than the pfa137. Can someone advise if the newer pfa130e is comparable in depth to the deeper or thinner box?
From one of many lurkers, the knowledge here is greatly appreciated.
Welcome Trucams,
iirc the junction boxes you mention are the same depth. You can check the data sheets on dahua for the exact measurements.
The wedge form is listed to fit with the PFA139 ( and probably also the PFA130E - but expect it the box to be wider in diameter than the PFA139 )
Welcome Trucams,
Sweet! Thanks for the quick reply.
