I've recently upgraded everything to PoE+ (aka 802.3at) vs regular PoE (aka 802.af) and then this came along. The only thing I'll wait for is a 2700k version but this is great for your cameras.
I don't do wifi because if you're going to run a power cable you might as well run PoE - if you need to reboot or power cycle you can remote to the switch and shut the port and turn it back on and you're done.
So my latest thing is I want to put a camera or two in a tree in the front yard so I can capture license plates. At the same time I have lighting on most of my cameras so I don't need to use the IR but do in some cases.
I was thinking the other day "wouldn't it be cool to have a POE LED light?" Well guess what - they have one - and you can also power the camera off it (and probably your in-line powered mic too!)
Check it out: Amazon.com: 8 watt PoE LED Outdoor Flood light with PIR Motion Sensor Detection, Bright White Floodlight powered by PoE, share one Ethernet cable for Light and IP Camera ( 48v PoE injector available separately ): Kitchen & Dining
If the link doesn't come through go to Amazon and search for B01N234FAL which is the Amazon part number. Evidently they have different versions with light sensors and it isn't that bright (640 lumens and 3700k-4000k) but I might just get one now that I am typing this just to check it out. Imagine the possibilities as LED gets more lumens per watt and you can run one cable for a camera and have light too.
I don't work for this company and have no affiliation - just saw this and thought it would be a cool thing and this audience here on ipcamtalk.com would definitely appreciate it. If it has already been mentioned - sorry about that.
Thanks.
Thanks.
