Kawboy12R
- Nov 18, 2014
- 1,763
- 609
I doubt it's a compatibility problem unless they did something funky with your pigtails. They're the ones that said other customers had wiring problems. I'm currently running the outdoor version of that dome as a critter cam with the exact same switch you've got. My indoor version is in use at work running off a passive injector. It ran fine off a LinkSys gigabit POE+ switch before I moved it. Here's the cam I'm running with the identical switch as yours- http://www.aliexpress.com/store/pro...-Indoor-Vandal-proof/1182439_32580365934.html
If it'll keep them happy, passive injectors are fairly cheap and are handy to have around anyway. Might not hurt to get one from Amazon or EBay to shut down their "compatibility" complaint and then you'll have it around if/when you might need it in the future.
Edit- I also had it running off a ZyXEL POE switch at one point.
