I want to test the free version, up to 8 cam.Which Milestone XProtect license are you planning to buy?
I run Milestone Xprotect Essential+ in an ESXi VM with 4 vCPU @ 2.0GHz and 8GB ram, H.264 w/ no HW acceleration. I get 10-15 FPS recording on all 5 cameras I own concurrently, including a 4K camera (was shocked). Other cameras are two 4MP and two 5MP. Try THAT with ZoneMinder!I want to test the free version, up to 8 cam.
@AveryFreeman I have plenty of Essentials+ installs that are running H.265 and hardware acceleration. Your setup won't have any hardware acceleration available on the recording side likely since they are vCPU's. It definitely does support the Intel HD and Nvidia hardware acceleration for smart client and also on the server itself. The mobile client takes huge advantage of hardware acceleration as well.I run Milestone Xprotect Essential+ in an ESXi VM with 4 vCPU @ 2.0GHz and 8GB ram, H.264 w/ no HW acceleration. I get 10-15 FPS recording on all 5 cameras I own concurrently, including a 4K camera (was shocked). Other cameras are two 4MP and two 5MP. Try THAT with ZoneMinder!
BTW Essential+ is pretty limited, there's no H.265 or hw acceleration, no intelligent motion detection, no access control device support. But it's rock solid and gets high frame rates on relatively inexpensive hardware.
Yes, that´s true, the perfomance of milestone is awesome!I run Milestone Xprotect Essential+ in an ESXi VM with 4 vCPU @ 2.0GHz and 8GB ram, H.264 w/ no HW acceleration. I get 10-15 FPS recording on all 5 cameras I own concurrently, including a 4K camera (was shocked). Other cameras are two 4MP and two 5MP. Try THAT with ZoneMinder!
Say it aint so!!Milestone supports both hardware acceleration for h.264 and H.265 on the recorder /mobile server and client side using as
@rsoxhater mentioned. Through it's entire range. Motion detection hardware acceleration on Essentials +, Express+ and Professional + only use Intel and not Nvidia. as for the client and mobile server they use both and for Expert and Corporate they two use both. In a VM environment this is also possible using Nvidia GPU's. If you look in their comparison chart tool both codecs are supported as per the following link on page 3
Yes that is correct, most server based CPU's do not support Quicksync and is only supported on i3,i5,i7and now i9 series chips.Say it aint so!!my R710 CPU doesn't support QuickSync AND I can't use NVIDIA?
I was looking to boost the performance of my home NVR
