Hi Everyone
I have 16 channel DVR DS-7216HQHI-K2, which is running well with 7 normal BNC cameras and 5 IP (Wifi & Fixed LAN) cameras.
Firmware is up to date on V4.30.120 build 200630
I have connected to the video output so that I can send the image to a second monitor and I am using the channel zero configuration to set the cameras I want to view.
My VGA monitor and view is fine and displays ALL cameras.
On the BNC Video out, however, only the normal BNC cameras appear even though the configuration allows me to choose the IP cameras, in the setup.
Is there a special setup for this DVR as I have set the same configuration on another Hikvision 8 channel DVR and that displays the ip cameras and standard BNC with out any issues
