The situation is I have a POE camera which has been using COAX to POE ethernet converters. It worked for a long time but has quit. Bought new media converters, new camera and it will not work over coax (even a short run) but will work directly hardwired between camera and NVR.
My question is there a way to connect one port of the NVR to one camera wirelessly? If so, can someone provide specific devices that would work? To clarify, I want to connect some kind of wireless device directly to a NVR port then connect another wireless device directly to a wired camera. I can get power to the camera but replacing the coax with ethernet cable is not an option. The distance is about 250 feet straight shot.
Thanks in advance,..
