- Nov 11, 2016
- 5
- 0
Huge fan of BI! It's been working really well for more than a year. I was able to wire the room where the server has been sitting with ethernet recently. Since then, remote access stopped working.
I changed the port forwarding settings to the new IP address that was assigned to the ethernet connection from the Verizon FiOS router. But, I still can't gain access to the machine from the outside. I can connect to the server on the LAN fine. If I put the server in the router's DMZ, I can connect! I'm starting to think I need to set the router back to defaults. I did delete the port forwarding rule and the protocol and recreated them without any luck.
