Hi All
The problem I struggle with is that there are horizontal black lines on the cameras in BlueIris (maybe it is not BlueIris to blame, but the analogue camera card's driver). The cards I am using are IEI's IVC-200G cards, the chips are Conexant BT878, four chips per four channel card.
In my experiments to try and solve the problem, I have noticed that I don't see the horizontal lines when I run Amcap.
In Blue Iris, under Advanced DirectShow Configuration, Stream/Format, Properties, Color Space / Compression, when I try to change the 'RGB 32' to 'RGB 24', as it is in Amcap, the value doesn't change, it remain 'RGB 32'.
Any advice will be greatly appreciated!
Best regards.
Hannes.
Best regards.
Hannes.
