Change in the OpenALPR CSV Export
DLONG2
789
467
This morning, the format of the exported OpenALPR CSV file has changed. There are a 14 new fields added to the export:
crop_location
gps_latitude
gps_longitude
img_height
img_width
plate_x1
plate_x2
plate_x3
plate_x4
plate_y1
plate_y2
plate_y3
plate_y4
processing_time_ms
This will require a bit or rework on the import-to-database process . . .
Reactions: tech101
Here's the placement of the new fields . . .
Another change is the format of the 'epoch_time_end' and 'epoch_time_start' strings. The newer format looks much easier to parse:
Old:
2019-04-29T11:37:10.672Z,2019-04-29T11:37:03.866Z,
New:
2019-05-02 03:55:23.909000-07:00,2019-05-02 03:55:17.707000-07:00,
Reactions: tech101
Another change is the date time stamps as shown above are no longer in universal time, but local time.
Reactions: tech101
Hi is there a script or a third party solution to download csv and process every 48 hours so we can retain data say in excel file ?
I wish I knew. My Windows application mostly automates by a one-click event using SendKeys in Visual Basic to effect the download from the website and import into my database, but wish there were a way to fully automate it and forget it.
Reactions: tech101
Two new fields have been added to the CSV export this morning: 'camera_ID' and 'site_id'.
And of course the 'epoch_time_end' and 'start' fields have reverted back to UTC time rather than local time.
