This will likely come across as a stupid question and I have tried to look up the answer here. I've just bought a number of ipc-t5442t-ze's and finished installing them. As stated in the manual, the default IP is 192.168.1.108 for all of them. They are now all plugged into a Unifi switch which is plugged into another Unifi switch which is plugged into the Unifi gateway. So my IP range will be 192.168.30.x and not 192.168.1.x (which belongs to the USG). Not only I now have a bunch of cameras claiming the same IP (sure, I can plug them in one at a time), but I can't access the UI due to the IP range. After doing some searching, it appears that I may be able to change the default IP using the Dahua config tool which is part of the Dahua toolbox which I would have to install on my computer. I've also tried to change the IP from the Unifi controller but obviously that did not work.
So can someone please tell me if there's another way to do this that doesn't require installing additional software? If not, is the Dahua toolbox safe with no risk for malware, and if so, what's the best place to download it from? Can someone please help?
