I am able to change profiles via http post, but I am now trying to change the brightness on a specific camera and I must be doing something wrong? I am using the following:
http://127.0.0.1:PORT/cam/StreetView/pos=25&user=USERNAME&pw=PASSWORD
I am using 25 based on the JSON info that indicated that brightness is button 11-26. The http response I get indicates "ok". But when I go back into Blue Iris and select the camera and then PTZ/Control and then Brightness, I see that it is still at level 4 - it did not change. It works fine if I manually click on brightness, in this case number 9, and so I know that the camera is getting the info from Blue Iris.
