Challenging camera use case, Is it possible under $1,000
oldspyguy
Jan 8, 2026
7
2
Cold North
The objective is to monitor a mailbox with enough detail to identify the vehicle as it stops and drives away. The challenge is the camera is 300’ away from the target area. I have been using a Reolink 811A 4K with 5x zoom but as we know their image quality is not applicable to this type of application. I have had better luck with the Hikvision clone with the same specs but realize I am asking too much from a camera with that field of view.
Below is the raw image from the 811A with the zoom maxed out and below that the image digitaly zoomed.
I probably need a 50mm lens to get the detail and would need two cameras to cover the target area which is fine. They are camouflaged in a stand of trees so size is a concern. I tried the best Reolink PTZ with 16x zoom but the image was disappointing and it was to large. A box camera will most likely be the choice.
The cameras are in the treeline 300’ from the road powered by a poe++ switch and wireless bridge 400’ back to the house. I would rather not bury cable out to a closer point as it might be noticed. I am open to any suggestions at this point.
So, does anyone have a camera suggestion that might work for this application under $1,000?
Thank you for any suggestions you may have.
Yeah a Reolink will never give you that.
The distance isn't a challenge. It is all the trees that will make it tough to get a clean image at night as they will absorb and bounce around most of the IR.
But for a clear daytime you need the 52IR-Z12E or a real PTZ not a toy Reolink.
One option might be the Triplesight
3 views in one.
Channel 1: 3.6 mm
Channel 2: 12 mm
Channel 3: 25 mm
The downside:
  • Daytime, fine. But like any camera you'll need light at the target at night. 300ft is a long way for IR without moving up to a PTZ
  • Its only 2MP so not high res as we think of it today
Otherwise, the 5442 Z-12 with a 60mm lens , same problem at night. getting light on target
Triplesight example
The mailboxes are at about 350ft
*No digital zoom used.
192.168.1.110_TripleSight1_main_20260220141645_@1.jpg 192.168.1.110_TripleSight2_main_20260220141646_@1.jpg 192.168.1.110_TripleSight3_main_20260220141646_@1.jpg
View attachment 192.168.1.110_ch14_20260220141640_20260220141650.mp4
In my opinion, the closer the camera is to the target, the better the chance of getting a good identifiable image, especially at night. Not sure if mounting a camera near the road is an option or not, but that would be the ideal installation. A bullet or PTZ camera will have a better chance of lighting up the target because of the amount of IR they emit.
Thanks for the suggestion.
The B521 looks interesting. Only 2mp but big lens. Would like to stay with 4mp or more if possible.
As for IR, I usually disable IR on cameras and use area illuminators or security lighting where possible. Eliminates spider webs, flying bugs, rain and snow at night, and seems to have an impact on longevity due to less heat in my experience but that might be just in my head lol.
Also these cameras are covert in nature so with the IR off someone cant quickly locate them at night with an IR filter on their phone camera. They stand out like artificial suns.
I have a streetlight being installed by the power company to light the end of the driveway and mailbox under the guise of helping firetrucks find my driveway to the dry hydrant in my 4 acre pond.
Attached is a photo or two from one of my B52IR-Z12E 2mp cameras. One is at 155 feet and the other is at close to 170 feet. Zoom is pretty much maxed out. I would guestimate that at 300 feet, the images will be close to half the size
3 views in one.
Channel 1: 3.6 mm
Channel 2: 12 mm
Channel 3: 25 mm
The downside:
Triplesight example
View attachment 238546 View attachment 238545 View attachment 238544
Wow, that triple sight looks great for 2mp. I guess a good quality 2mp sensor is better than a crap 5mp sensor any day. Looks like the onboard AI and triggers are robust as well. My eyes are opening lol
Thanks...
Yeah, to get the focal length you need, it is either that 2MP or the 2MP triple cam Bigredfish suggested or you are going to a PTZ. A 4MP (Z4E) on the ideal sensor size (1/1.8") caps out at about half the focal length of the Z12E and at 300 feet, The 2MP Z12E will beat the 4MP Z4E all day long.
In fact, people using the 2MP Z12E at 70ish feet bought a 4MP Z4E for the same spot as a "better" replacement and ended up going back to the 2MP Z12E. Focal length is important.
Since you are kinda new here, I am posting a thread I created showing that the appropriate focal length for the distance needed is far better than a higher MP camera with less focal length. Plenty of examples within that thread demonstrating this.
Digital zoom only works in the movies and TV.
A 2MP camera with the focal length for the distance in question will beat a higher MP with lessor focal length all day long.
Thank you!
I knew I was missing something in the matrix, I was wondering why all the high end Hikvision cams seem to be 4mp.
Glad I joined up.
You only know what you know ;)
Thank you.....
