Thanks, I will look into that.Alarm.com uses cellular for monitoring. Here is the equipment that I use; DIY or a local company can install. Upgrade GE Simon XT - To ??
Alarmgrid.com has good information. I didn’t buy from them since I had a local connection but they have a lot of videos on their YouTube channel that answered a lot of questions.Thanks, I will look into that.
Note this cannot be used as primary. It won’t let you add sensors and make certain other changes while on cellular.Ring alarm has cell backup.
This is one reason I didn't go with Ring.Note this cannot be used as primary. It won’t let you add sensors and make certain other changes while on cellular.
The ring operating over the internet connection then fails over to the cellular - that is not a negative unless like the OP you dont have an internet connection. Ring has the same smash and grab protection as well as the smoke and co listeners. Its not on the same level as Qolsys but is insanely cheap to buy and the monitoring is only 8.33 a month.This is one reason I didn't go with Ring.
My first system was Simons XT which worked fine but not having a display and having to program everything via long, complex keypad strings was a pain. After 9 yrs of use when the system started having issues I did a lot or research and decided on the Qolsys for the following reasons: They are backwards compatible with other wireless sensors so I did not have to re-invest on sensors that I already had. The types of available sensors (branded and third party) is extensive; I like the door sensors that are recessed into the door than the ones that are visible. I even purchased a sensor that just listens for the smoke detectors to sound and then notifies the fire department. All the programing can be done right at the display with a very easy UI. The display is handy to tell the current status of the alarm, easily identify errors or if a door or window was currently open. The display has a camera and takes a picture of whomever disarms the system. They accept Power-G sensors which work at further distances with higher encryptions. A secondary display (even a third) can be added for other entrances; this also acts as an signal extender for the sensors. And there are many sensor groups to assign each sensor so you control when or if it reports to the central monitoring or just notifies the user.
Cellular is the primary and mandatory, internet is optional. I also like the redundancies and algorithms. If an exterior door is opened a signal is immediately sent, monitoring then expects a disarm signal to be received within 30 seconds; if the burglar smashes the display so that the alarm can not be sent, the system knows something is wrong and notifies the authorities.
I consider Ring sort of like Lorex; prepackaged, cheaper systems for the novice who wants a quick DIY plug-n-play system.
Depending on where I am stationed, the wife might come stay with me a while so we would suspend cable tv and internet service. Yes $9 a month isn't bad, I pay @$27. I don't know what type of building c hris527 want to monitor and what type of configurations he needs (i.e. multiple partitions).The ring operating over the internet connection then fails over to the cellular - that is not a negative unless like the OP you dont have an internet connection. Ring has the same smash and grab protection as well as the smoke and co listeners. Its not on the same level as Qolsys but is insanely cheap to buy and the monitoring is only 8.33 a month.
Remote Building/Garage lots of high value assets, it has ac power perhaps 4 window and two door alarms and perhaps something for a garage door, he does have a remote for the garage door.Depending on where I am stationed, the wife might come stay with me a while so we would suspend cable tv and internet service. Yes $9 a month isn't bad, I pay @$27. I don't know what type of building c hris527 want to monitor and what type of configurations he needs (i.e. multiple partitions).
look at a honeywell vista system with cellular communicator. This will allow you to wire up some loud speakers for alarm all over the building and outside.Remote Building/Garage lots of high value assets, it has ac power perhaps 4 window and two door alarms and perhaps something for a garage door, he does have a remote for the garage door.
Is the building and garage attached; if detached, how far apart?Remote Building/Garage lots of high value assets, it has ac power perhaps 4 window and two door alarms and perhaps something for a garage door, he does have a remote for the garage door.
this is 3000' non line of site from any house. Its only a storage building in the middle of heavy Forrest.Is the building and garage attached; if detached, how far apart?
