Hello,
I'm upgrading from my summer cottage CCTV system. The current system includes a Hikvision NVR with three IP cameras connected. Current cameras are wired with a Cat6 cable. Three surveillance cameras will not be able to monitor the entire property, so the intention would be to add at least two new cameras and upgrade the NVR to one of the VMS software. I do not like Hikvision’s iVMS softwares/apps.
The biggest problem is that it is not possible to cable the property entrance surveillance cameras. The only option would actually be to put the cable underground, but it is too expensive and time consuming. Do you have any ideas for doing this? Maybe WiFi on cameras, etc.?
I have not yet decided which VMS software to choose, maybe Milestone or Blue Iris. I am very familiar with a few CCTV/VMS softwares like Hikvision iVMS, Mirasys, Lenel, but I would like to try something else. Opinions are welcome here. The VMS price should be less than $ 75. I’m probably building a suitable workstation for VMS and also considering NAS recordings and remote access.
The aim is therefore to make the system as cost-effective as possible, but of high quality. The plan is not in a hurry, the system is to be installed in the spring when the snow has melted.
Sorry if a similar thread already exists but I couldn't find it.
