- Mar 29, 2018
- 7
- 1
My new house will be prewired with 4 cat5e cables for PoE cameras.
It could be upgraded to Cat6 (for extra $$), wondering if I need it in near future (5-10 years?)
Seems like 1000Mb from Cat5e is 100 times of current bitrate and no way I will ever need to tap into Cat6 extra bandwidth. Thoughts?
That kind of downward angle is what I call a bald spot camera.When you guys are saying too high, what do you mean? They are putting it near soffits, so around 10'.
You can even get an ideal what a location will be like by just taking a photo from the location. Helps to have a helper with a hat. Also don't plan on super wide angle cameras, a somewhat narrower FOV is more useful in most cases, plan on 80 degree fov or less.test your locations ASAP before the cabling gets done.
HELL TO THE NO!!!!!!!!!!!!Not sure about doorbell, these days all good doorbells are wireless.
Thanks for the tips. Not sure about doorbell, these days all good doorbells are wireless.
I have a corner townhome, which has three walls open to the outside. Seems like 3 cameras should be good. I may add one more at the side wall, since its pretty long and one cam won't be enough.
