About to purchase IP camera NVR system and while they typically come with CAT5e, if running wire, may as well do CAT6. I need to upgrade my existing computer network runs anyway which I believe were the original CAT5. No problems with the existing 2 network line which are primarily data. In my research 'educated' on EMI which I never considered a decade ago...but I have a mother of an install with a potential EMI generator. Will replace the two existing computer runs and add four (or more) camera runs along the same path. From the bedroom wall it goes straight through to garage then up the garage wall (not in wall!) into attic. No conduit, just cable tacks to support but with more cables will use conduit for the run to the attic with this install. Placement is the issue as the lines up the garage are between the two (120 and 220) breaker boxes and of course enter the attic right where the main service line connects to each breaker.
Should I just do unshielded as planned and hope for the best? If I do shielded CAT6a or CAT7, then you have grounding issues where the metal terminals need to be grounded with either the NVR or IP camera (but not both creating a ground loop) creating the ground at their terminal. Essentially, the j-45 receiver on the NVR would have to be metal, not plastic. Has anyone had any experience with this?
