(Flintstone 61 fires himself for leaving himself unfriendly tape ends and using blue Plenum cat5e.)
Get out!I use a remote controlled toy tank to get a pull string in insulated or suspended ceilings. It helps to add a couple of LEDs, one red one green, so they're visible to aid in steering and location.
I'm looking for some advice about pro's/con's of cat5e versus cat6 for long distance runs to IP cameras.
The distance from the network room to the furthest camera is approximately 450 feet (137 meters). There are several IP cameras at this distance.
We are organizing to use Dahua 4MP cameras using power over ethernet. I do see that Dahua has some proprietary "ePOE" switch but not sure if this is Dahua specific technology or if a Ubiquity or other brand POE switch can do the same.
Do you have any suggestions on cat5e versus cat6 and any particular POE switch recommendation for long distance runs to IP cameras? I'm not against having a POE switch at the mid way point but also don't necessarily want to do so if we can get away with one POE switch.
Also what other characteristics should we go for the ethernet cable in terms of STP/UTP, how much AWG, etc? All ethernet cables will be indoors although may be subject to some high heat (110+ Fahrenheit temperatures during the summer)
