CAT5e ok for cams?
MrRodgers
Sep 22, 2021
55
27
NJ
I need to buy 1,000 ft of indoor cable should i buy CAT5e or 6?
CAT6 seems like a waste since IP cams will never need 6?
Suggestions?
Cat5e has enough speed for IP cameras.
Benefit to Cat6 is the wire is slightly thicker. This means a longer distance for POE runs.
Is that the ePOE i hear about?
It helps with both standard POE, ePOE (long distance) and POE+ (high power POE).
It's not directly related to one technology.
+1^^ to @Mark_M 's recommendations.
Just make sure it's solid (not stranded), pure copper (not CCA / Copper Clad Aluminum) , with a CMR (Riser) jacket for use in walls, ceilings, attics, crawl spaces and between floors.
I've got 15 home runs to my BI Switch with Cat5e from Tru Cable. all running well.
16 if you count the Nano station feed.
Cat5e is all I still use even for new installs. Easier to work with and 10Gbe isn't needed for home installations unless you have a real unique install going on.
CAT5e it is then. Is the jacket on cable that is CMR more tear resistance? I know it's a fire rating.
I could see a need for CAT6 with all the cams being 4k maybe?
I have a outside POE switch that all my cams run to that are outdoors then a single cat5e cable runs into the house to my switch, i wonder how many cams it would take to bottle neck that one cat5e cable going into the house.
Someday i would like to fix it. :)
Cat5e when installed correctly can handle link speeds up to 1000Mbps
A 4k camera might have a bitrate delivering around 10Mbps depending on the codec in use and the video quality selected.
That's around 1.5% of what a gigabit link will handle.
What's the spec of the uplink port of your PoE switch?
Reactions: Flintstone61
If its a 1Gbps switch, it would take a lot of cams. Lets say its an 4MP cam at a CBR of 8192kbps. 1Gbps / 8.2Mbps = ~121 cams to fully saturate the link.
It's a 1Gbps switch. TPlink
